london flower seller [manda]
Postby mikemeister_admin » Sun Feb 17, 2008 1:41 am
I had to make at least 4 passes in CM.
I set neutral points for the wall and windows.  I think I should have left more of an orange cast in the wall to reflect the true tone of the stone.
I tried to use masks for the window and failed, but did use the skin mask for a skin pin which worked a treat.
I used a slight lab boost for the flowers but didn't worry too much about this as the photo has a dreary feel and didn't need cheerful roses.
I must admit to setting the final layer to screen mode just to create selective brighter areas via masking in photoshop.
Postby -default » Sun Feb 17, 2008 2:47 am
Nice result, Manda.
Users browsing this forum: Bing [Bot] and 7 guests
