I have used the L mask twice. once normal and once inverted.
all with extra bent L curve in the good direction.
Alos used a elements 6.0 highlights ( is also a mask)
frits
Toy-shop
Fritz,
You certainly got deep into the back of the shop. Good job...
Can you make the color pop a bit more??
indeed , i had to do that. i lost 50 euros there, so i hoped to find it.
I could make more color, but i do than only more saturation on the finished picture, and that is so easy, you believed , i can.
Yust i would spent more time on beta-testing you know. I have done that not much so far.
On that reason, i will pass over several new classes, till i am very far in beta-testing.
Also, i had to renew my knowledge in Hidden Powers and more things.
So, i stay very busy. I had to less time.
I have foned to above, to give me another extra liive.
