Wk5 Ex 6 Toy store
Postby imported_ganna » Sat Feb 16, 2008 5:58 am
I tried to lighten up the back of the store without loosing too much contrast in the front. Firstly, I added fill in light (8) in PS before going to CM and mask and saturation
Postby -default » Sat Feb 16, 2008 7:05 am
Definitely brought out a lot of detail in the back of the store.  The lighting is probably fluorescent, so there is a greenish cast.  There are now at least two things we've covered that you could use to fix this problem - mask the darker areas and remove the green, or move the black end of the G curve horizontally.  Or combine both of them.
Postby imported_ganna » Sat Feb 16, 2008 10:53 pm
Look less like people from Mars. I Tried to ungreen them a bit.
Postby ggroess » Sun Feb 17, 2008 5:46 pm
You did kill off the Martian look but you also muted the colors a bit...is there a compromise??  possibly not but it might be worth a look see.
Postby imported_ganna » Sun Feb 17, 2008 8:58 pm
This is overdoing masking and ending with artificial colours, but definately not a member of the green group anymore
Postby ggroess » Sun Feb 17, 2008 11:58 pm
ok...I deserved that...LOL
Good Job!
