I tried this process on some of my own images and found that if there is not a good contrast between the land and sky the results not quite as good. I'm sure the process will be useful in the future.
Thanks Joe S
Wk 5- Ex 2 Lake Harbor
I think the process is sound...
The mask choice makes a big difference in the results...
Mike chose the K channel here because of the resultant mask and the part of the blue sky that is contributed by the K in CMYK But remember that you are not making a CMYK adjustment...you are only using the information from the K channel to create the mask.
Try another mask on your other images or post he image so we can take a shot at it an let's see what other masks we could use...
