Wk 5-Ex 1 Black Tassels
Postby mikemeister_admin » Fri Feb 15, 2008 6:19 pm
I wasn't able to make the tassels black. They still have a bit of red.
Thanks Joe S
Postby ggroess » Fri Feb 15, 2008 10:05 pm
Joe,
Are they red or do they have a red halo??
If it is a red halo open the mask up a bit so that it is not as contrasty...
that will allow the adjustment to bleed over into the edges of the masked areas a bit and remove the red halo...It also fixes the shadows.
Postby -default » Sat Feb 16, 2008 1:27 am
Another possibility is the slight tilt to the a curve - that would add red to black.
