WK-5 Example 2
Postby mikemeister_admin » Fri Feb 15, 2008 2:21 pm
Between bringing my grandchild to school an get them an bringing her again i have intensified experiment with the second exampe and seen the video a couple of times and also the end of the purple dog.
I use CM 3.05 and my K channel is not black in the sky.
I think of that reason the steeping the K channel starts not like the example-video of Mike about 12 points but on the opposite site of the curve surface.
So far after several tries there is no problem, and i could give the sky more  or less blue and light.
But the problem is the K mask.
Like the purple dog gras there are points in the black area K mask which may be corrected.
I made a copy of the mask. But when you see the copy , you see a whole different picture as when working  on it before.
So bringing in that mask in the Hue-selection layer is no problem.
But the problem is  more to correct the mask itself.
the most is white, and is more diifficult to correct. I get the most important black, but near the edge of the sky it is very difficult.
So what to do?
p.s.
Copy of the K -mask, when he is nearly black, only the sky!
Strange is the copy of it.
Postby mikemeister_admin » Fri Feb 15, 2008 3:52 pm
the last 000.2 jpg is the mask copy when it looks like the first one.
Postby mikemeister_admin » Fri Feb 15, 2008 4:16 pm
It is like HD photography!
Postby mikemeister_admin » Fri Feb 15, 2008 4:33 pm
I have doen it with the B (lue-channel).
that chanel looks better to me then K
Postby ggroess » Fri Feb 15, 2008 5:23 pm
LOL on the tornado....
As for the second image you could give it some more contrast in the mid range of the image.  It has the effect of sharpening it up a bit and lowering the forground lighting just enough to balance the image some...
I used a contrast pin on some of the brighter green leaves and just moved it a bit...otherwise to me the image looks a bit flat...
Postby mikemeister_admin » Fri Feb 15, 2008 5:38 pm
like this one?
Postby ggroess » Fri Feb 15, 2008 6:01 pm
Sorry Frits...the second image being "as new"
without the boats...just the lake and sky image...
Postby mikemeister_admin » Fri Feb 15, 2008 6:45 pm
oké, pinned the contrat on the lake edge above with the green!
Postby -default » Sat Feb 16, 2008 12:46 am
I think you need to set your GCR to maximum to get the K mask used in the example.
Did you see the video on using the K channel as a mask?
http://curvemeister.com/downloads/Class/c1s5/video/mask_k_channel_gcr/mask_k_channel_gcr.html
Postby mikemeister_admin » Sat Feb 16, 2008 12:52 am
Mike ,
indeed, i have seen it several times.
but i used not the K channel but the B channel.
It looks to me better.
But if you like i will do the K channel next day.
Now  i go to bed.
It is nearly 1:00H o clock midnight in holland.
frits
