Wk5 Ex1 Tassels
Postby imported_ganna » Thu Feb 14, 2008 5:12 pm
Here is my effort.
Question: How do you copy a mask? I know how to copy a channel, but for instance if I want to copy the mask of the tassels from CM and pate it into CS3 as a copy, how  do you do it?
Mike, the scroll buttons does not work (scrolling through masks but the alt+. and alt+, works)
Postby -default » Thu Feb 14, 2008 5:27 pm
You can copy the mask by clicking on the mask tab in the image window and clicking the copy icon - it's the same as copying other channels.
The scroll buttons, if I understand correctly, only appear when the window is too small to show all the tabs.  In v3.0.5 there are next and previous buttons under the Mask tab.
Good job on the tassels, by the way.  I hope this answers your questions!
