Version 3.0.5
Postby -default » Wed Feb 13, 2008 8:55 pm
If you are still using version 3.0.1, I recommend upgrading to 3.0.5.  There are some known issues with wgCMYK for the older version, as well as some hue clock issues with masking.
There is a bug with the installer that may cause your pins to disappear.  To get around this, click No when the installer asks if you want to remove the old version of Curvemeister.
If you are using v3.0.5, and getting strange hue clock behavior, please let me know.
Postby mikemeister_admin » Fri Feb 15, 2008 11:13 pm
How do I upgrade to version 3.0.5?GregM
Postby -default » Sat Feb 16, 2008 12:40 am
3.0.5 is available here:
Postby mikemeister_admin » Sun Feb 17, 2008 9:37 pm
Mike,this is a screenshot  of the mask carte that opens when I hit the mask button.I've tried inverting the mask different ways  but wind up with a really crappy image where theforeground and hill darken.GregM
Postby -default » Sun Feb 17, 2008 10:43 pm
The K channel is too light.  You need to change the GCR setting to Maximum Black.
http://curvemeister.com/downloads/Class/c1s5/video/mask_k_channel_gcr/mask_k_channel_gcr.html
Or use Lightness or the green channel, un-inverted.
