Ex 2 and K mask
Postby mikemeister_admin » Wed Feb 13, 2008 4:39 pm
I'm really having trouble with the K mask - can never get a dark one like you, even on maximum.
All the mask previews, whatever the GCR setting show the sky as white, not black as in your notes!
So I then had a look at the video which shows a white sky - I'm completely comfused, how did you manage that!
Postby ggroess » Thu Feb 14, 2008 3:34 am
Zog,
The sky needs to be white so the curves effect the sky.  Make sure you select the k mask and not the k channel.
See my shots below...
Shot 1 is too much slope in the k curve almost vertical.
Shot 2 is backed off a bit.
