jaguar
Postby mikemeister_admin » Sat Feb 09, 2008 8:52 pm
last year i did the same car , but make it green like the fire-brigade -car. that was easy.
teh jaquar is more difficult.
when I was experimenting i get this result.
When I may believe the hue-clock it is yelow ?
Why ?
p.s. also the floating hue-clock gives these result.
Postby mikemeister_admin » Sat Feb 09, 2008 9:04 pm
my yellow Car.
Postby mikemeister_admin » Sun Feb 10, 2008 12:27 am
Great color.GregM
Postby ggroess » Sun Feb 10, 2008 3:46 am
now that's hitting one out of the ball park fritz...Great job...
Postby -default » Mon Feb 11, 2008 9:05 am
Hat's off to you, Frits.
Postby -default » Mon Feb 11, 2008 9:10 am
Re the yellow color.  I don't know why, but unlike the other primary colors, dark yellow never looks yellow.  It tends to go toward green or, if it has any red in it, it will turn brown.  By the same rule, if you want a good yellow, you will generally need to add brightness to it.  There is one color space where this is not true, HSB.  In that color space all colors are defined as being equal in brightness, and there would be no need to bump the brightness of yellow.
