I noticed this today...
If I use the color picker and I select a color but do not close the window when I go back to CM the focus is still on the Color Picker and i cannot do anything. I went for the Ctrl-Alt-Del solution but first I tried the minimize the application trick and when I did I found the color picker open.
I closed the color picker and maximized the application and all controls were restored...
I did not intend for the color picker to be sent to the bottom of the pile so to speak...I simply click on CM after selecting a color for a pin.....
Color Picker gets stuck under the application
