my doggie problem.
Postby mikemeister_admin » Fri Feb 08, 2008 9:59 am
Mike or Greg,
I have seen the doggie movie several times.
to choose the a mode and do my thing is no problem.
But you choose for our exercise now the b channel.
So, i have experimented 45 minutes to get a good contrast.
So far i know, i did all possible and strange movements with the b channel.
I do not succeed in doing it.
So I need help, alas.
Give me a hint.
p.s. at last i placed to info points on the gray lab and see , the colors are close together, so how do i enlarge the distance?
frits
Postby ggroess » Fri Feb 08, 2008 2:44 pm
Fritz,
You have shown the channel correctly now you need to rotate the curve so it gains contrast.  You want a B&W "mask" in the window when you are done with the adjustment.  The grey tones you are showing will not make an effective mask...
See screen shot below...
Postby mikemeister_admin » Fri Feb 08, 2008 7:47 pm
I understand it fully!
So i have send you a .avi file of my problem.
Perhaps you see what I do wrong.!
I do not get a good contrast in the b cbaneel, what i do.
p.s. with the a channel I have no problem. So what do i wrong?
Postby ggroess » Fri Feb 08, 2008 8:07 pm
ummm...A channel Fritz...
B is not a good choice for this...here is my b channel...
I think I could save his tongue...you are not trying to correct the channel here just create the mask pattern.
Postby mikemeister_admin » Fri Feb 08, 2008 8:47 pm
thanks!
I will use the a channel.
you can make lot of colors, but I like a yellow dog.
Postby ggroess » Fri Feb 08, 2008 8:50 pm
yes but yellow is so...last week...
I mean a Purple Retreiver...who can top that...
I think the only thing left is plaid....
Postby mikemeister_admin » Fri Feb 08, 2008 8:58 pm
indeed week but difficult.
oké, a purple boxer then!
Postby mikemeister_admin » Fri Feb 08, 2008 9:11 pm
here is the purple doggie!
frits
p.s. Why talk Mike about b channel in his instructions ?
Postby mikemeister_admin » Fri Feb 08, 2008 9:29 pm
I have my doggie done very quick!
I have seen now that Barry has a more purple and nicer purple doggie!
so i must spend more time on it. Perhaps another time!
frits
p.s. how is the song ?
there is a doggie in the window.... waf... waf ?
Do you know the song ?
Postby -default » Fri Feb 08, 2008 9:32 pm
I made an error in the instructions.  I have fixed it to read "a channel" instead of "b".
Thanks for pointing this out.
