WK 4- Ex 4 Colorized Dog
Postby mikemeister_admin » Fri Feb 08, 2008 2:16 am
Mike, I was able to colorize the dog but have problems with the CM3 program.
1) When I copy, the copy layer mask button behaves funny. It seems that most times I have to click it two or three times. When it proceeds its process bar goes to 95% and stops.
2) If I ignore that and continue on it seems that I get some results as shown in the attached image but I don't know if its right or wrong.
3) If when I copy the layer, let it go to the 95% finished, walk away and come back its still there at 95%. If I click on cancel it gives me the following message: " could not complete CM3 command because DVPDoc::ReadPixelsFromLevel:read PixelsProc error: stop".
4) I had the internet and other pgms open and thought that they may be consuming too much ram (I have 2G) so I closed them. Did not make any difference.
Thanks Joe S
Postby mikemeister_admin » Fri Feb 08, 2008 2:45 am
Mike, I just read the post by joyed who has the same problem.
Thanks Joe S
Postby -default » Fri Feb 08, 2008 3:06 am
Yes, I've got it on my short list of bugs to fix.
BTW - it is helpful to mention a bug again even if someone else has reported it.  Sometimes, if I only hear from one person, I assume the bug is lower priority.
Postby imported_ganna » Fri Feb 08, 2008 4:14 am
I have the same but it seems that if you just press the copy button once, it does copy although the indicator does not show up. It's when I press the copy button for the 2nd time that the indicator show up but then get stuck at 95%. Just my 2c worth
ganna
Users browsing this forum: Bing [Bot] and 7 guests
