Skin Tones Pin File
Postby ggroess » Thu Feb 07, 2008 9:13 pm
Here is a Pin File I have created for skin tones.  Copy this txt file to your pin folder...
It is based on the attached image.
S = Shadow
H = Highlight
N = Normal
Postby mikemeister_admin » Fri Feb 08, 2008 5:14 am
Mate thank you so much - I've spent all morning playing with my skin tone actions in PS and seeing how I can translate them into CM - it looks like you have saved me a long job.
Postby ggroess » Fri Feb 08, 2008 2:37 pm
Wonderful...Glad to be of help...
You can tweak the colors by editing the pins if youu feel that they are "off".  We will be covering this in the next week or so...
Postby mikemeister_admin » Fri Feb 15, 2008 12:29 am
Greg, can you explain where these files go exactly. In CM I have Swatches>Goodies, People, Nature. Only some are "pins" in CM. How does one make them "pins".
Thanks Joe S
Postby ggroess » Fri Feb 15, 2008 1:11 am
Joe,
Copy the SHN Skin tones file to the swatches directory. just paste it there and then you can either re-start CM or refresh all pins from the right click menu
Users browsing this forum: Bing [Bot] and 7 guests
