WK 3- Ex 7 Cathedral Shadow Cast 2
Postby mikemeister_admin » Sun Feb 03, 2008 10:21 pm
I watched the video and 5 minutes later I had a hard time with the desired results. After quite a few tries I think I've done better.
Thanks Joe S
Postby -default » Sun Feb 03, 2008 10:45 pm
Is this a second pass in Lab?  The key to removing the blue is to get the b curve off-center, by moving the yellow end of the curve, using the hue clock as your guide. Both of your curves are still centered..
