1) the lab image was only adjusted using the pin and ends of the a/b curve.
2) In the RGB image I also tried to remove the blue cast. Didn't quit make it.
Thanks Joe S
WK 3- Ex 5 Drummers
Joe,
Remember to use the "worm" to help you figure out where to make your adjustments.
http://www.curvemeister.com/wiki/index.php?title=Color_Worms
It can really make it easy...
