WK 3- Ex 4 Monkey
Postby mikemeister_admin » Fri Feb 01, 2008 9:24 pm
It was interesting to adjust for the other colors after pinning the guys nose!
Postby -default » Sat Feb 02, 2008 2:14 am
Yes, it is a lot harder to adjust the colors with a pin active in Lab (or any other color space for that matter).
It's easier if you click on the pin icon in the lower right corner to un-pin the pin.  Then you can adjust the endpoints of the a and b curves to get a good compromise between the neutrals and the skin tone.
