St Vitus steeple
Postby mikemeister_admin » Thu Jan 31, 2008 12:21 pm
Did change sky color.GregM
Postby ggroess » Fri Feb 01, 2008 4:49 am
This on can be tricky...You look visually and you see a green steeple, you think adjust the green.
The real fix is in the B channel and blue adjustment.  You got there partially but you need to make a new control point closer to the center.  You can use the mark function to place a mark on the B curve where the darker side of the steeple is.  Then pin the yellow side and adjust the shadow until the clocks are close.
