Screen Shots
Postby mikemeister_admin » Wed Jan 30, 2008 11:33 pm
What is the procedure to include the hue clock and curve charts along with the image. For ex: WK 3 Ex 2 has the hue clock as part of the image for class transmittal.
Thanks Joe S
Postby ggroess » Wed Jan 30, 2008 11:42 pm
Joe,
I use  program called Gadwin Print screen.
It's freeware for the older version, allows you to scale the image and save as a jpg.  .
It allows me to grab the screen without losing even the cursor.
I can point to things on the screen with the mouse then...
Postby mikemeister_admin » Thu Jan 31, 2008 12:16 am
I use a program called MWSnap. It is freeware and is fine for the amount I use it.
Postby mikemeister_admin » Thu Jan 31, 2008 1:13 am
Thanks Guys. I'll check them out.
Thanks Joe S
Postby mikemeister_admin » Thu Jan 31, 2008 9:49 pm
Thanks Joe S
Joes,
I don't know how good these freeware prgrs are.
I use for years snagit from Techsmith.com.
It is a very good prgr. It can  lots of things.
Also capture video's from screen-sequences.
I have never regret fom this prgr.
frits
Postby mikemeister_admin » Thu Jan 31, 2008 11:39 pm
Thanks.Now I just have to learn to tame it.GregM
Postby mikemeister_admin » Fri Feb 01, 2008 12:29 am
I loaded down Gadwin Print Screen. Used it once and it worked. Yeah!
Thanks Joe S
I'll write down the other suggestions and if this one should give me problems I'll try one of the others.
Postby ggroess » Fri Feb 01, 2008 4:32 am
You can set it to 800 X 600 as a default and It will size the image for you...or..you can make some other changes like save to clipboard or save to file
It really is a handy little widget...
Greg  ;D
