Cookies
Postby mikemeister_admin » Wed Jan 30, 2008 10:47 pm
My try at the cookies. The numbers I have seem reasonably close to yours Mike. How does one get a hue clock with both text and  the clock as you have it? Mine does not have the letters around the dial, also can the size be varied?
Postby ggroess » Wed Jan 30, 2008 11:49 pm
Barry,
Each hue clock has it's own settings.
See print screen below
You can also click on the arrow in the hue clock and get the second menu.
Postby mikemeister_admin » Thu Jan 31, 2008 12:19 am
   I can change what I have, the problem is that when I ask for the clock and text, The clock portion only has a line, no letters around the dial. Could it be the version?  The ones you show are the clock only. Size?
Postby ggroess » Thu Jan 31, 2008 1:01 am
Barry,
I am on 3.0.5  Mine always displays what I ask it to....
Mike??
Postby -default » Thu Jan 31, 2008 1:53 am
Barry, click on the wrench, select Preview and un-check the "mini hue clock" option.
Postby mikemeister_admin » Thu Jan 31, 2008 1:58 am
Thank you Mike, that did it.
Postby ggroess » Thu Jan 31, 2008 1:22 pm
Should that go to the hue clock menu with the other hue clock controls??
I never would have thought it was there...
Postby -default » Thu Jan 31, 2008 1:32 pm
Yes, or the option could just be removed.  It is in the manual:
http://curvemeister.com/support/curvemeister3/help/Manual/ImageWindowOptions.htm
