Weekend Challenge 01/25
Postby mikemeister_admin » Sat Jan 26, 2008 6:00 am
Since you were all so dillgent in completing you images early this week I'm posting some images to give you something to do this weekend.
1) Airplane: The airplane image was taken near Hanksville Ut. See what you can do to brighten and get detail in the plane and keep the background clouds dark.
2) Crow: Bring out the detail in the crow.
3) This image is underexposed. Brighten the foreground (with detail) and keep the clouds a nice grey.
Thanks Joe S
Postby ggroess » Sat Jan 26, 2008 5:08 pm
Joe,
I am really having fun with the Crow image...Thanks alot...
Try it in HSB once...you can almost amke the crow and rock look like a cut out....
I'm going to keep playing with this a while...
Postby mikemeister_admin » Sat Jan 26, 2008 6:01 pm
Both pictures first "shadow highlighting 50 % in Premiere elements 6.0
After that  shadowpoint on the wheel and neutral on the ground.
and so on and so on.
I have lot to do, so I spend less  time on each photo.
frits
p.s. it looks a picture from Flight simulator!
Postby mikemeister_admin » Sat Jan 26, 2008 6:13 pm
I told you , I have less time spend each picture.
hEre is the crow.,
I did first shadow highligt 25 % the whoel picture.
After that used the quick selection tool on the crow and did again shadow hight light 50 % on the bird.
I think afterward the bird is to light.
When it is a raven, it should be nice black.
So bumping the colors in LAB and afgterwars correcting t omuch blue in the background.
so i am quick ready.
frits
Postby mikemeister_admin » Sat Jan 26, 2008 6:25 pm
so the last one.
all pictures together i did in about 10 -15 minutes , I think.
in practice in the real world you take most often lots of pictures.
there must be a golden rule how to quickly improve your pictures without to use much time.
You could always spend more time for special pictures.
Could Mike learn us that also ?
Postby mikemeister_admin » Sat Jan 26, 2008 6:31 pm
Plane pictures tack sharp,very nice.GregM.
