Setting neutrals on the stairs and gray stones.
You see the curves.
Angor Thom from king Jayavarman ( 1300 BC)
Hey Fritz,
It looks like you did not set a shadow point. All of the stone appears to be above middle grey. You have tons of detail but hardly any shadows...
oké, you are right. But the step is darker.
the tiltle of the picture I gave is not right. It is a RGB picture.
After that I tried to place the lab picure with curcve.
But I got the message the Folder is Full. I send that to Mike.
I will trie to place the lab-picure to day.
