Sun moon lake in RGB mode.
Postby mikemeister_admin » Fri Jan 25, 2008 8:57 pm
perhaps i had to do the lab mode o a different way.  But i like the picture.
In RGB mode I set the neutral on the same place.
So I could shift the neutral ( s) upwards.
also manipulating the rgb mode and each channel.
every time I compared it with the lab end result.
This result is different  and i like it to.
You can see different things on the right o on the mountain.
frits
Postby ggroess » Sat Jan 26, 2008 4:01 pm
Good job Fritz...
I'm glad you are exploreing the different color spaces...
I l ike this version as well as the other one...
Postby -default » Sat Jan 26, 2008 9:28 pm
Very nice, Frits.  I like the lighter, misty look as well.
BTW - I'm going to be hanging a large print of this particular image on my wall, probably a dark version more similar to Zog's (Chris's).
