suggestion from Mike to use the metal frame als a netral.
that is possible. But afterwards there stays a color cast.
I have tried to compensate that in the a channel.
Fruit Vendor
Indeed but, that would put the pointer between the Green and the Yellow. Not so close to the yellow.
I think you will find the change to be subtle but effective...
oké, but using the frame as a neutral is a good thing , Mike suggested.
But, then there resists a resistent green cast.
Must i let exist that ?
