Ex 1 week 2
Perhaps I was struggling, wrestling and scuffling too much with this image. I simply started again; in RGB I put the highlight point in the cloud, the shadowpoint on the small rock in the water (distant) and used the roofs right bottom as a neutral and simply moved the curve vertical as a floating neutral. Is this more of what you had in mind Mike? It is easier if you take a photo yourself; when you know what effect you want before you even start. Not serious excuses, but sometimes not clear as to what effect is the better one.
cheers
cheers
