Didn't really understand what was expected. Played with different versions, I think this was the best.
Thanks Joe S
WK 1 Steel Balls
It is a bit of an abstract image. The idea is to get some familiarity with placing the shadow and highlight, and this image has served well in the past.
In addition to this, I have a sort of private agenda with this image. Each of the balls, in the full sized version, actually has some trees, with sky detail that includes clouds and a bit of blue. It is possible to correct the entire image by correcting the image reflected in each of the balls, using Lab to get blue patches in the sky, and even a bit of green in the trees. Out of hundreds of people, no one has seen this picture within a picture. After an absence of a year or two, I started using this again an example, to see if anyone will see the reflected images, and color correct them.
