I adjusted the image 3 ways 1) Wizard LAB. 2) Wizard RGB, 3) Curves. I tended to like the RGB version. Maybe only because it ended up darker. I toyed with these images maybe 15 times and find that when I said to myself "its done" that the end result was different. Using curves I think I'm able to target areas more specifically if I look for them. I find that I am not as critical with the images normally. After coming back from a trip with 500 or 1000 images I may be only critical with a few that "pop" out at me.
Thanks Joe S
Wk 1 Duck Images
