Some of you have noticed that I'm using a newer version of
curvemeister in the videos.
The beta versions are available here:
v3.0.5
Curve highlighting? Yes, I believe I changed the way it works, from a keyboard toggle to a button that you click that turns curve highlighting on and off.
v3.0.5 is installable. The main problem I'm getting reported from some people is that all their pins are disappearing! This seems to be a registry related problem that as a workaround can be fixed by manually adding a folder name to the registry.
The loss of pins is more universal than I thought! I'll have a fix for this very soon.
In the meantime, I've enclosed an *experimental* .reg file that I hope will fix the problem, and in any case will help me to diagnose what is wrong.
The .reg file sets the appropriate registry entries to point to the new location. Perhaps the bravest among you can try it out and post a note here.
