Yellow Flower
Postby mikemeister_admin » Thu Jan 17, 2008 5:46 pm
Mike,here is the flower using the 125KB download.Is the curves box included?Greg M
Postby mikemeister_admin » Thu Jan 17, 2008 5:50 pm
I cant see it GregM
If you have the full version of CM, then you can put a link into the .avc file - otherwise I use to take a snapshot - or copy the curve data as I mentioned to Mandy and just paste the text values into the postings
Good luck!
Chris
Postby mikemeister_admin » Thu Jan 17, 2008 6:49 pm
Thanks,Chris.GM
