Setting the 3 points
If I set the 3 points Shadow, Highlight & Neutral and then delete the Neutral - all curves are reset (in rgb) - is there anyway of not loosing the Shadow & Highlight?
I have noticed that for al long time ago. I thought is was normal.
They are resetted, but the points still are there. Clicking on it, repairs the old working.
so you lose only the neutral point in this case.
frits
