Hi Mike,
Suddenly (?) when I go to the CM forum, I only get the above 2 showing - none of the usual ones.
Is this right?
Chris
Classes & announcements
Within Classes, you should be able to see two groups - they're actually called boards - one for Enrollment and another one for this class. A few people may also see any previous class that they took.
Outside of classes, there should also be the usual groups for General Discussion, Curvemeister, Photoshop and Elements, and Challenges, each with a number of boards under them. If they're not there, make sure you are not down one level - the link is http://www.curvemeister.com/forum
If you click on the forum link above, and only see two boards, let me know and I'll do some more digging.
