Dark day in duckland
Very nice...
Some things to watch for...the highlights on the belly of the duck are pretty hot. Did you try out the Thresholding feature for the highlight??
http://www.curvemeister.com/wiki/index.php?title=Thresholding_Using_Highlight_and_Shadow_Points
overall the color looks a bit muted...Mike likes to use the term "Pedal to the Metal" when it come to saturation. I preferr the old saying.."Tighten the bolt down until it spins free then back it off a half a turn" either way you should try out pushing the saturation a bit.
In Lab there is a "Saturation Slider" you can use to really crank it up...not too garrish mind you. I always go until I feel I have gone too far and then come back until I think it's believeable.
