Hi Mike,
If I fire up CM3 from an image in Lab mode, instead of RGB (which I normally do), and set the High point (in either lab or RGB) - it places the point on the curve inside the axis rather than on it (which it does if I open CM from RGB).
Can't work out why?
Chris
Setting the Highlight point
