I love the ability to "see" the underlying image on the curve while working on the mask, really helpful. Also, the hilite mask dropdown options are perfect--the mouse worked fine; I didn't have to type in numbers, it is very cool. But then I decided to check on the Hilite curve, and I couldn't get it to work. As I fiddled around with the curve and the preview, the entire ribbon and toolbar became grayed out and is not functioning. I switched tabs and everything is still grayed out. The curve window is the only thing working.
I just went back to CM and everything was working again, and the colorpicker box was opened, and nothing is grayed out, and Hilite curve works perfectly. Thanks for taking care of that so fast, Mike.
Hilite curve problem
