Well, I also like the size of the newer mask carte, but now it doesn't work the same way it did in 3.0.2. If I pick a b mask (fer instance) and make my curves adjustment, I can no longer choose other masks from the ribbon and see the changes in the preview, like I could this morning; if I change to a skin mask I see no change in the preview window, though the name changes in the curve window and in the dropdown.
If I reset and choose the skin mask, however, it does change and show the same curve and mask I was just using on the b channel. Also, I'm sorry to say none of the masks will invert or blur right now.
I'm not sure what Greg did this time.
mask carte bigger but broken?
