I noticed that when I hit Ctrl-F, nothing happened. Going to Browse History takes me to the Documents directory and asks for a file name.
I had processed several images so expected the ACV file to be somewhere. A search found no recent ACV files. I did, however, find all of them from version two - in the Curves 2/History subdirectory of Curvemeister.com. A look in the Curves 3 directory showed no History subdirectory.
What have I done wrong... and how can I fix it.
Ron
(Curvemeister 3.1.0.1 - Vista Ultimate - Photoshop CS3 Extended)
Lost History in version 3
The most common reason for this problem is file permissions. If, for some reason, Curvemeister is not able to create the History folder, it will silently fail to record the history file. Since you have a working Curvemeister 2 history folder, I'd recommend that you merge the two.
Assuming you installed the Curvemeister support files in the usual place, the attached .reg file should point your new Curvemeister 3 installation to the history files for Curvemeister 2. if not, please let me know and I'll follow up with instructions on how to manually edit the history file folder name in the registry.
I have no CM2 history folder nor do I have a CM3 history folder.
Does the program create one on install? If so it is not showing up on my Vista Machine. Just like Ron I went looking for the history files but do not have any.. :'(
I figure adding the reg patch makes no sense if there is no history to point to...
To make history work, change the HistoryDir registry entry to point to a folder in which you have write permission.
I'll be addressing this in the next release, probably by moving the history files to "My Documents". This should fix the problem on Vista, as well as for the occasonial XP and Win2K system where this problem turned up.
The same goes for pin files.
