Hi Mike,
I've been working on that cup image again, and when I opened in CM, I realized that my worms weren't visible on the CM or Y curve. (okay on the composite and K, as well as all other channels.) After a lot of fooling around trying to figure that out, I found that my 16 bit version of the cup image doesn't work, while all 8 bit versions do. I changed the 16 to 8, and it worked, switched it back, no good.
Opened another 16 bit image, can't see them. I have a screenshot, if you need it.
Gloria
16 bit and CMY
Stop prowling, Mike. I tried it on a few more images, and then opened it with the demo version, in which everything worked fine. I know this is quite impossible to believe, but I was somehow on the last version. My husband loaded if for me Monday night--I thought it was installed, apparently it wasn't. Sheesh. Anyway it is now installed, or reinstalled, and it works.
Ummm, sorry?
I mean Greg distracted me.
Though how come I had the new tooltips?
Ummm, sorry?
