Hi Mike,
When you look at the Hilite curve problem and if window docking comes into it, I find I can only dock the curves window to the left top of the CM area and horizontally along the top - because my screen is 1600x1200 I like to have the curves in a vertical window and down the right side of the screen.
Would it be easy to allow the curve window to be docked to the top right corner?
Chris
Window docking in CM3
This is pretty much the way I use it. There is a sweet spot, about 1/2 inch or so from the right edge of the main window, where you can dock vertically to the right inside edge of the main window, though not specifically the upper right corner. Then expand the main window to cover the whole screen and Bob's your uncle!
