1. In the ribbon bar, under "Curves", the "Other" box is not sized correctly. The same is true for Color Sample/Hue Clock, and Settings/Grid Lines.
2. When toggling to another application there appears a white line at the very top of the CM window above the Quick Access tool bar, the CM version, the image name, and the current color space. This white bar disappears after changing menus (i.e. from "Curves" to "Mask") in the menu bar when, it appears, the CM window is redrawn.
v23
2 small interface issues
