First time I ran the program after install I got the attached Print screen and blown out of PSE.
I re-booted and got the program to run.
When I did get it to run I went to LAB and set a highlight.
The threshold mask came on and hid the image except for the highlights but then but would not revert back until I set a shadow point.
When I set the shadow CM3 placed it in the lower right corner of the image not where I set it and I had to move it to where I placed it.
After the shadow was set the image returned to normal view and I was able to threshold the highlight with the correct behavior.
The Exception was on an XP workstation with SP2 applied.
New Bug
