Keyboard accelerators
Postby -default » Sun Oct 21, 2007 7:55 pm
Some of the newer keyboard accelerators, such as ctrl-R for toggling the ribbon, won't work unless you reset your prefs.  This can be done using the Reset All button, under the friendly Keyboard tab in the customize dialog.  Screenshot enclosed.
