rotate arrows in Lab
Postby mikemeister_admin » Sun Oct 21, 2007 3:05 am
This is certainly not a big deal, but in Lab the rotate arrows don't work quite like they do in the other modes. They stay in vertical mode even when moving horizontally for quite a bit longer.
I just went back in and adjusted the L curve, and then moved it back again. The arrow then went really squirrelly, and started changing orientation incorrectly all along the borders.
HSB is exactly the same.
Actually, I need to modify this again...it seems if I modify a curve by dragging the upper right corner towards the center a little, and then click and drag  the rotate tool around the border, it just starts flipping around in circles. It really hates that.
Postby -default » Sun Oct 21, 2007 4:49 am
Yes - I just tried that .  It is trying to rotate the curve with just one end point selected.  Not a good thing at all!  I'll add some improvements tonight.
