What effect would you expect from placing a pin on a mask? I've no idea, really, but I tried it anyway.
What actually happens is that the pin is applied as if the image was showing, not the mask. I suppose that kind of makes sense, although I'd expect the pins to then disappear when the mask is shown. Otherwise you get the effect shown in the screen shot attached which doesn't make sense.
On the other hand, dragging a monochrome pin to a mask to set one area of it to a given shade of grey might have some merit. Maybe.
Pinning on a mask
Interesting - at first glance. The screen shot is definitely not what I expect to see.
Right now pins should be hidden when the mask channel is showing in the preview window.
The clock numbers should only reflect the before/after state of the color image. The before color is based only on the source image, and the after color is the source image as shown on screen, allowing for any masking and combined with the background color if there is transparency.
