can't drag control point off
roy
Postby roy » Tue Oct 16, 2007 11:23 pm
was playing around with a saturation curve in HSB.  Found I couldn't drag one of the points off the grid to delete it - it got to about 10% from top and then wouldn't go any further.  (I've come across this a few times before but not been able to replicate it)
Postby -default » Wed Oct 17, 2007 12:29 am
Not to say you haven't found a bug, but there are certain times when a curve point can't be dragged off the curve.  The end points can't be deleted.  The other - legitimate - time you can't delete a curve point is when it is created by a highlght, neutral, shadow, or other pin on the image.
roy
Postby roy » Wed Oct 17, 2007 9:55 am
sorry, can't remember how I created it.  but I do remember that it did delete with the delete key (if that helps - I'm not at a PS pc at the moment so can't test myself)
Postby -default » Wed Oct 17, 2007 10:43 am
There are some strange interactions between color pins and points on the curve, so I wouldn't be surprised.  If you get a repeatable combination, let me know and it will at least make it to the bug list.
