This is another harmless bug someone brought up--
If you run your cursor over any of the masks aside from Skin in the preview window, the curves readings reflect the composite image. If you do this on the skin mask, it seems to reflect the mask itself. Skin isn't a channel,true; but does it have special powers? I should probably go find this question--I hope I didn't miss an explanation.
Skin mask
