Mystery Bug...
Postby ggroess » Sun Oct 14, 2007 2:31 pm
I recall a bug listed here but I cannot find it where I think it was Derek lost the ability to add a control point to the curve.. He tried various methods of restoring the focus to the curve and we could not reproduce it...
Well, Last night while working on some print screens for the Wiki...
I ran into a bug where I could not add any control points to the lightness curve in LAB.  At first I could not even select the existing curve control points.  Then I clicked on compare, nothing happened..It was as if the focus went off into la la land and never was to return...I almost hit Ctrl-Alt-Del and killed the program..
Then I tried switching color spaces.  I clicked RGB and the program responded. When I went back to LAB, I was able to add points to the curve and move existing ones.
So..here is what I can add to Dereks previous issue with lost focus...
If you use an outside program like Printscreen, and take the focus completely away from PSE and CM3, it may not return the focus correctly to the CM3 program.  I'm going to try different combinations around this to see if I can make it happen again...
Postby -default » Sun Oct 14, 2007 3:49 pm
I would love to nail this one.  I've run into this on rare occasions, but never gotten it to happen again.
