The Reset button on the Mask ribbon is in a highlighted state, and has a tick next to it on the Set Mask menu. Does this make sense? I thought it was a button that performed a function - a mask settings reset - as opposed to an indicator that the mask is in the reset state.
If it's the latter, perhaps rename it to something that's not a verb. "No mask" perhaps, matching the "No blur" entry further down the menu?
Mask reset item is ticked/highlighted
