Ribbon
Postby mikemeister_admin » Sat Oct 13, 2007 2:21 am
I know this isn't important right now, but while I was customizing my toolbar, I lost part of the default lower bar--from chan: to Set Mask. I got it back through regit, but before I did, I realized that the mask carte icon ( and Set Mask) isn't available in the customize menu, nor is it on the ribbon. There was no way I could preview any masks. (sad moment that was).
I thought it might be nice to collect all the mask icons in one place (for consistency:) ) being that there are five, and they're kind of spread out. They are all nicely placed together on my toolbar, now.
Postby -default » Sat Oct 13, 2007 4:28 am
Now that you mention it, it is easy to wipe out the last part of the Tool bar just by resetting it.  I'll change this so that you can always get back to the original tool bar by resetting the tool bar in the customize menu.
Now you got me thinking.  How about a separate Mask tool bar that gives you access to all the mask commands?
New release soon, after I fix, or try to fix, the latest crash you've found.
Postby -default » Sat Oct 13, 2007 5:57 am
Whoops - a little harder than I thought to simply create a new mask bar, or even to make it easily resettable, so this will probably not be added in the near future
In the meantime, I have added Show Mask command and Set Mask sub-menu  to the list of custom commands, so it will be easier to get back again.
Postby -default » Sat Oct 13, 2007 8:51 am
Figured it out.  As of v .16, resetting the Main tool bar restores all of the original commands instead of losing the tail end of the command bar.  You will need to answer yes when asked to reset the tool bar the first time you start Curvemeister for this feature to become active.
