Well, here's a rather useless bug report, but I'll send it in case anyone else sees the problem and can build on my report.
I was playing with the HiLite Curve function and managed to get a couple of points selected in my b curve. I started moving them and the curve guard cut in - I had a really weird up and down shaped red curve. In order to start again I dragged one (or maybe two, I can't remember exactly what I had selected) of the points off the curve graphic and CM3 locked up. No error, no crash, just an unresponsive window and a mouse cursor fixed as a 4 way arrow. I had to use Task Manager to kill off PS and start again.
I haven't been able to reproduce it as yet.
Lockup
I have noticed that when the curve gaurd kicks in you have to re-select the point you were working on. It's like the focus does not come back to the selected point. Once you click on the point you can move it out of red-zone...but..If you move it out and back in it drops the focus again...
This is how it is in 2.X as well...
