master curve window
Now that you mention it, I did remove that feature from Curvemeister 3. The traditional cursor on the RGB curve is misleading, because it reflects an average value for the three channels, which is misleading unless the object in question is gray.
I'll see about adding it back in, probably as several markers on the RGB master curve, one for each channel.
